TS9 Trouble Shooting, installed IC socket and new op amp, now very low volume.
Started by mojohand315, October 06, 2012, 05:44:33 PM
mojohand315
So I installed a IC socket and new chip on my TS-9, went to test it and I am getting almost no volume out of the pedal and sometimes my speakers will get overloaded and make a *farting* noise.  (sorry I don't have a better way to describe it, almost like the speaker is blown or has too much resistance maybe?)  I took it apart and started poking around with a multimeter.  7 of the 8 legs on the IC chip have voltage readings.  The one exception is on pin # 5, which is attached to the tone circuit.  I also have 0 voltage values on the the 220 ohm resistor that is attached to the .22uf cap.
http://www.generalguitargadgets.com/pdf/ggg_its8_lo.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
I'm pretty sure my problem is with either c5, c9 from this diagram
or in the tone section of this one
http://www.freeinfosociety.com/electronics/schemview.php?id=1088
The two .22uf will read voltages on the pins not touching the 220 ohm resistor inbetween the two.  I replaced the resistor and one of the caps (the ones next to pin # 5) and still nothing.  Please help.
oomnelson
Ok, I suppose you have the IC in the right position, right?.
I think you have to check the solderings in the socket, It´s probably a bad solder, or a cold solder what is causing the low volume or the "farting" noise.
I wish you luck !
mojohand315
The IC is in the right position.  I am one who would normally f that kind of thing up so I checked thoroughly.  I'm going to solder that connection again and see if anything changes.  I also found this http://www.thegearpage.net/board/showthread.php?t=848266 which deals with all of the parts I am having trouble with (it's those two blue caps and the resistor between them) but there is no page 2 that tells you what to do after removing them.
oomnelson
The blue caps, are tantalum caps (polarized), change them by polyester caps.
mojohand315
Ok, I resoldered pin # 5 and the one leg of both the .22uf cap and 220 ohm resistor that are all attached to each other.  I am still getting no voltage readings from any of these three.  Also I had previously replaced this cap with a poly one, should I do the other one now?  I am trying to avoid replacing a bunch of components before I figure out where the problem is and I get myself into a situation where I gotta call Mike.
oomnelson
I agree with you, don´t change anything else. Those caps and resistor affects the tone, and it don´t represent a problem. What I would do now, is to check all the wiring looking for a disconection or something that can affect the way of the signal.
mojohand315
I replaced the other .22uf cap, against my own wishes.   I now have a full functioning pedal but the battery does not work.  In addition there is a bit of a volume drop when the pedal is plugged in vs. the guitar going straight to the amp.
oomnelson
What a relief when everything is sounding again...  :icon_wink:
About the volume drop, must be because the pedal is not "truebypass", you can add this issue to your list of mods.
Greetings from Argentina !
