Silicon Fuzz Face 3PDT LED Wiring
Started by sidewalk, October 25, 2012, 03:51:04 PM
sidewalk
Hey, I've been using this layout to build a silicon fuzz face.
However, I want to be able to add an LED and use a 3PDT footswitch instead.  A power supply jack would be a good addition as well.  This is my first veroboard build, but I've built kits and PCBs into enclosures before.  I'm not sure where the input/output of the circuit and how the pot wiring is set up so I can't use a layout like this.
Can someone point me in the right direction? Thanks.
Dom D
It will be easier to understand if you label the wires. In the Fuzz Face layout, the light purple wire coming from the third row from the bottom and going to the top left lug of the switch is the input wire. The output wire comes from lug 2 of the volume put. This is something you'll see on a lot of builds.
sidewalk
Quote from: Dom D on October 25, 2012, 04:05:03 PM
Okay, that makes sense.  Where is the ground on the circuit board and/or pots?
Kesh
The green wires and everything they touch is ground.
