using MAX1044 on Frobnicator
Started by mantella, October 20, 2012, 03:29:28 PM
mantella
is the Frobnicator setup to use +/- 9v ? If so, i should be able to use the tonepad MAX1044 circuit with it so I can use the usual 9V wall adapter, correct?
lonewolf
you dont need the max1044 since this circuit doesnt use a bi-polar supply..but the one I built would not work with a tl072 ..I changed it to a tl062 and It worked fine..no voltage issues...etc..great sounding tremolo..ditched the EA and the pulsar in favor of the frob
mantella
weird. Any ideas why it wouldn't work with the TL072? Only reason I ask is that I don't have an 062.
lonewolf
you can find more info on other threads here..use a socket for the ic and then you can swap..it is supposed to work with a tl072 but the one I built wouldnt.why?..good question...hollis specifies a tl062..there are issues with the voltages and the led's are supposed  to be matched,but I had none of those problems with the 062..but it is tricky adjusting the trimmer to subdue the carrier frequency when in the ring mod mode..you  cant completely eliminate it..but I think it is a great sounding device..I like all of the hollis designs..
