Multiple Voltage Power supply
Started by juan_felt, November 16, 2012, 02:01:26 PM
juan_felt
Hi again!
I have a question to make, I made the power supply from tonepad http://www.tonepad.com/getFile.asp?id=111 and I want to add an extra 12VDC output. My idea was to use another LM317T with a resistor of 1k to get 12VDC. The problem is that I don't know what parts I can use commonly in both outputs, meaning, the rectifier diodes and the 470uf caps, the problem is the D5 diode, I don't know what it does exactly, and if it may bring me trouble.
Thank you !
Kesh
D1 to D4 and the 1000uF/2x470uF are common.
Everything else should be doubled up.
D5 prevents the 47uF cap discharging into the LM317
