lo fi pt2399 layout question
Started by timd, November 20, 2012, 10:08:36 PM
timd
I have a question on this layout:
http://www.aronnelson.com/gallery/main.php/v/Renegadrian/PT2399+lo-fi+delay+vero.gif.html
a and b are marked "10p" and "47p". What value capacitor is this? Way too small to be picofarad right?
cloudscapes
Might be. The chip runs in the Mhz so those would be good cap values to filter noise out from the rails.
{DIY blog}
{www.dronecloud.org}
timd
I have used 100n for both a and b to some good effect. This circuit needs some type of power behind it though. I'll try an amp chip...
armdnrdy
#3
The designations "p" or "pf" for capacitors denote picofarad.
1 microfarad (uf) equals 1,000000 pf
With that being said, those "small" 10p and 47p caps aren't too small to be picofarad.
As I was writing this you wrote that you were using 100n caps in place of the 10pf and 47pf.
Just so you know 1 nanofarad = 1000 picofarads your quite a bit off the mark of how it was designed.
Kesh
The data sheet suggests 47u for B and 100n for the A caps.
knutolai
According to Renegardian himself (in another thread, cant seem to find it right now) that circuit woun't give you very musical results. At least try putting a buffer in front of it ;)
