aion electronics halo fuzz not working
Started by jman77, March 09, 2016, 02:40:36 AM
jman77
built the pedal to creamy dreamer specs and nothing. sound in bypass mode but when i engage pedal no led and no sound. here 1st pic.
https://imgur.com/a/UndBm
will take it out of enclosure tomorrow for more pics. maybe something is wrong in this pic tho. any help would be awesome guys thanks
Cozybuilder
First, welcome to the board
Assuming the jumpers in resistor slots are accurate, the transistors bent over like that makes me wonder if one of their legs could be shorting on something? I see they're socketed, so take them out, bend a kink into the outer leads so the spacing is right, clip them to about ⅜" from transistor body and reinsert, observing orientation.
I can't tell anything about the wiring from the photo.
Did you solder in "Tone" and "Mid" pots? I see a mid bypass jumper, so maybe that pot is not needed? There are also a couple of other component slots left open- a diode and what looks like it should hold an electrolytic cap. Verify that all components needed for this version are correct value, and oriented correct on the board.
Finally, it looks like the volume and gain? pots attach one end of the board, but I don't see how the other end is mounted in the enclosure- is there a method to assure that the soldered side does not short on anything in the box?
Let us know if this helps
jman77
im on my way to help build a garage today so itll be later before i can bend those transistors and then pull the pcb out. according to the build doc i got everything in its place. it mentions nothing about those empty component spaces not even a word about using jumpers in them. heres the build doc
https://aionelectronics.com/wp-content/uploads/2013/11/aion-halo-bmp-documentation-v1.5.pdf
. ill upload more pics tonight
antonis
Imagine TONE pot seat connected..
(but you may say I'm a dreamer...) :icon_wink:
Are you getting any noise out of it at all? The fact that you're not even getting an LED tells me you may have wired the switch incorrectly. Can we see how you wired that?
jman77
sorry it took me a bit to reply. i freaking used the weong lug on the 9v adapter. switched it and it works.
