Can't find the PDF with typical stompbox parts
Started by pappasmurfsharem, December 03, 2012, 11:38:36 AM
pappasmurfsharem
There is a PDF floating around somewhere that has typical parts (enclosures, jacks, leds, pots, knobs etc...) I had it at one time and I can't seem to locate it now.
the parts were generally 1:1 size ratio which made plotting out a box before assembly rather nice.
Any help is appreciated.
pappasmurfsharem
armdnrdy
Does this mean I'm not going to have to pull out my micrometer to measure new hardware every time I layout a box?
It never dawned on me to keep all of this info in one easily accessible place! I would pull up a PDF for each new piece.
Definitely a time saver!
tip: make a template in inkscape or whatever for the box type you use hammond/eddystone (there are slight differences)
download the enclosure's pdf for the inner/outer dimensions..1590b/1590bb etc etc..
then everything is 'actual size'.
a real time saver, and can be used for drill templates too. ;) makes for a neat job.
armdnrdy
Hey Rob,
I do make templates for each build. It makes all of the difference in the world for a superior layout. I use Visio. In the beginning, I was putting blue tape and measuring every box!! What a pain!! What was I thinking?
I like this pdf idea for pre build/template reference. One quick glance and all of the info is in one place. I keep different PDF folders semi organized by component type, but as I said for quick reference, this PDF is a good idea.
GGG has PDF drill templates for a few of the popular enclosures and Inkscape iworks great for modifying (unprotected) PDF's.
http://www.generalguitargadgets.com/tech-pages/45-schematics/249-drilling-enclosures
...and Goefex has a nice pdf guide for 150bb boxes with various parts. I used the Geofex guide to create similar templates for the various boxes of other sizes that i use.
http://www.geofex.com/FX_images/hmbbtpt.pdf
dave
