Help with enclosures!?!?
Started by Ark Angel HFB, December 07, 2012, 11:49:58 PM
Ark Angel HFB
Will someone please for the love of all things good and holy help me find an enclosure that is just a wider version of a 125B, that doesn't cost 30 bucks.  ???
side note: this might be a good place to compile a list of enclosures from smallest to largest. could be helpful to people wanting to know what to build in. XD
"..So I hooked up the power and it was the greatest Radio I'd ever heard. Too bad I was trying to make a Tremolo..."
chi_boy
You could take a look at Pedal Parts Plus.  They have a lot of options and will drill and powdercoat too.
http://www.pedalpartsplus.com/
-George
"Great minds discuss ideas, average minds discuss events, small minds discuss people." — Admiral Hyman G. Rickover - 1900-1986
The Leftover PCB Page
Ark Angel HFB
I have a drill a uni-bit, spray paint and water slide decals... I'm all set on the finishing side of things... what I need is the next logical size up from a 125B...
basically same height... twice the width would be ideal. or at least very close to that.
Ark Angel HFB
Oh lord never mind I'm a lazy fool... XD
So... 1790NS seem to fit the bill nicely... I wish they were a bit cheaper but I'm not going to complain about 2 or 3 bucks difference.
Ark Angel HFB
Not exactly... I'm doing some slight rounding between what different sites list and my own measurements
125B   = L-220mm & W-64mm
125BB = L-220mm & W-94mm
while it is wider... it isn't twice as wide and for the pedals I'm making, if I want two effects in the same box there are also issues with stompswitch spacing.
Bassically I need a box that is (L=220mm & W>=220mm)
which is the 1790 box in a nut shield..... although I wish there was a version that was exactly twice as wide and then one exactly three times as wide... XD. Can't hurt to dream I guess.
Jdansti
This may or may not help, but I'm trying to put together a table of the more commonly used enclosures here: http://www.diystompboxes.com/smfforum/index.php?topic=100340.msg882800#msg882800
You might also want to check here:
Hammond Enclosures: http://www.hammondmfg.com/scpg.htm
Eddystone Enclosures: http://www.hammondmfg.com/eddydwg.htm
kodiakklub
try the hammond 1590XX. its what EH uses for their larger boxes. i wish china was pumping fakes of theirs out to all the pedal parts sites. until then, mouser it is.
