dr boogey problem
Started by firko modor, October 02, 2012, 08:39:05 AM
firko modor
Hi to all willing to help,
I made the dr boogey from this well known site http://gaussmarkov.net/layouts/drboo/drboo-perf.png
Built the pcb myself and connected all the elements on the board
Now after connecting the power to the board i got voltage readings on only 3 trimer's  (TRIM 2 and 4 which can be adjusted,while the voltage
on trim 1 it is always 7.9 volts no mater how much i try to adjust the value)
On trim 3 i am not getting any voltage reading at all
Truth be told I used 2 resistor in series to get 2 M ohm's    and  1N4007 instead of 1N4004
Also i am using a  ac-dc converter that has an output of 8.2 V and that is the only difference to the original
I haven't found any shorts,or elements put wrong
I tried to put a normal resistor in place of the trimer 1 (50 K Ohm) and got 5 V but still nothing on trim 3
Also replaced the trim 3 with a normal resistor and still nothing
Please help me i want to boogey  :icon_eek: :icon_eek: :icon_eek:
lonewolf
do you have 9v on pins 1 and 2 of the trimmers? are all the electrolytics oriented right..I would look for some broken traces or something shorted ..check for continuity along the 9v rail to the trimmers..use a magnifier to look for a hairline crack,etc
jmwreck
I would like to ask something different on my build. there is a very low output on my pedal and I have noticed something, I measured the 9v and Ground (DMM at Resistance settings) for connectivity which there should be no connection for both, but I do get a resistance in there. I tried to pull out all the Jfets and the 9v & Ground connection is gone. I wonder if those Jfets created those connections, or is it really suppose to be like that?
Using the Jfets that I have pulled out, I measure it using the same setting above, from D & S, I've also got a reading.
There is usually "some" conduction across the circuit's power connections.
With BJT transistors it may be very very slight (high resistance) until you apply some voltage (more than an ohm-meter).
> all the Jfets
Ah. An unbiased JFET may be like a 300 ohm resistor. You may have another 10K of actual resistance in series with each JFET. So a several-JFET circuit is likely to look like a several-K resistor.
jmwreck
#4
schematic
layout
Ive made my own perfboard layout, can you help me verify it? I have made the second build last night and still no sound, I was thinking of the j201 to be the problem, since I just removed them from the first build and mount it to the second.
