Digital Tube Screamer
Started by m0xpd, December 24, 2012, 08:25:35 AM
m0xpd
I've been experimenting with a TS clone under digital control - the ability to flick between stored "Preset" configurations is great!
Read about it at: http://m0xpd.blogspot.co.uk/2012/12/digital-ts-rocks.html
earthtonesaudio
Nice!
Do a fuzz face next.   ;)
kingswayguitar
digi2t
QuoteNow I need to decide on how I'll arrange some footswitch control.
Can it be MIDI based? That would be cool for my rig.
Absolutely smashing work! Thanks.
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
J0K3RX
MoltenVoltage
Quote from: digi2t on December 24, 2012, 11:54:18 AM
We have a MIDI-based Four Pots module that uses 4x AD5290 Digipots which we chose instead of the AD5242 since they can handle up to 18 volts and 5 mA.  While they are limited to 100K, you can run them in series to get higher values and use a parallel resistor to get lower ones.
Nice work indeed!  The days of multiple copies of pedals are over!
MoltenVoltage.com for PedalSync audio control chips - make programmable and MIDI-controlled analog pedals!
Ronan
MoltenVoltage, you have very impressive products that are not expensive, I hope you do well with your business, all the best.
