A simple XLR momentary A/B - will this work?
Started by spargo, March 23, 2011, 05:38:03 AM
spargo
There will be an LED activated when the switch is thrown - hence needing a 3PDT and not a DPDT.
The above schematic is older and I believe is pop-less on one channel.  I've since improved it.  If you're interested, once the full design and switching is finalized I can send you the info with parts list, etc. and I will likely have some PCBs left over.  I'm sticking this in a 125B enclosure.
harmonic
That would be better than great! I'm pretty keen to try the Mammoth switch, actually. :-)
spargo
Are you just building one?  I have 4 of the switches just sitting here...I'll cut you a deal. :) I can ship it with a PCB once those get made.  I'm probably looking at 2-3 weeks if all goes well.
harmonic
alexm0428
#24
Hi.
@Spargo, can I PM you to ask you for the improvements you've made the original circuit?
I'm very interested in building my own.
Thanks.
pufferton
Hi Spargo i'm looking to make a few of these and was wondering also if you had an updated schematic/parts list? also if you found a way for it to not drop phantom when switching?
