Old BOSS FA-1 FET Amplifier
Started by J0K3RX, January 06, 2013, 11:34:17 PM
J0K3RX
I have seen these go from $200 to $500 on ebay... Are they worth it...? I think NOT but I thought somebody may find it interesting since you don't see these too often... They do sound really good from the sound clips if you like that Edge/U2 sound!
Anybody built this?
http://www.diystompboxes.com/smfforum/index.php?topic=95022.0;prev_next=prev
http://www.matsumin.net/diy/bunkai/BOSS_FA-1/index.html
http://trabantland.wordpress.com/2009/05/27/boss-fa-1-project/
Clone
http://trabantland.wordpress.com/category/diy-guitar-effect-pedal-projects/boss-fa-1-clone/
pappasmurfsharem
roseblood11
My vero layout is verified as well:
Leave out R17 or use a higher value like 2m2 or so...
It's a great little tool, the controls are quite flexible. I have it at the end of my chain, just to cut out some bas frequencies or to boost my AC-15.
But it works really good in front of overdrive pedals as well.
Highly recommended!
zombiwoof
A user on the now-defunct Bossarea Forum, and now the replacement "Stompbox Zone" forum, named "Laurie", made a line of boutique pedals called Dingotone, and he made a run of FA-1 clones that were supposed to be great.  He only made a small batch of them, and they got scooped up fast.  He has now turned his business over to another user on the Stompbox Forum, and retired from commercial pedal building.  It was mentioned there that the Boss version is very rare and expensive these days.
Al
Mich P
A member called EUREKAIV as made a very nice pcb for that boss FA-1
i don't know if they still available :
http://www.diystompboxes.com/smfforum/index.php?topic=89583.0
Mich P.
J0K3RX
#5
Quote from: Mich P on January 09, 2013, 06:25:15 PM
Mich P.
That is a nice board! I think smallbear has the HA1457 SIP Hitachi chip and the 2sk246-GR FET...
No activity from EUREKAIV since July 01, 2011...  :icon_frown:
BubbaFet
The silkscreen on the PCBs say "Germicon Effects"...http://www.germicon.com/
Looks like a nice little project for a self build and something i could use if it sounds as good as some of the clip on you tube.
Save to favorites, put on a back burner until i get more bits and make it a future first IC/fet project.
What do you think?
roseblood11
Nobody needs the HA1457 and the 2sk246. Why use noisy old parts if there are better new ones available? Mojo bullshit...  ::)
I used a LM833 and a J201, most other dual opamps and n-channel jfet's will work
J0K3RX
Quote from: roseblood11 on January 10, 2013, 12:29:40 PM
Nobody needs the HA1457 and the 2sk246. Why use noisy old parts if there are better new ones available? Mojo bullsh*t...  ::)
You're right!.. I was just going by that 2 sided pcb that EUREKAIV created using the original parts..  I will go with your design but I am going to draw it for pcb. I have plenty lm833's and j201's.
roseblood11
why don't you use the ustomp layout?
J0K3RX
Quote from: roseblood11 on January 10, 2013, 08:24:04 PM
Ah ha! Nice.. Thanks man, I didn't even see that :icon_redface:
roseblood11
...but don't forget to use a 0.47µF film cap where the layout has a "47µF non-polar". Maybe you could increase the leg spacing to 5mm.
J0K3RX
Quote from: roseblood11 on January 11, 2013, 03:32:46 AM
Well, that's good to know cause I am fresh out of "47µF non-polar" caps ;)
