Marshall Shredmaster
Started by ianmgull, November 18, 2009, 08:45:31 PM
ianmgull
Anybody know of a PCB for the Marshall Shredmaster? I've only seen the BYOC version. Any info would be appreciated.
ubaid88
http://www.diystompboxes.com/pedals/schematics.html
Here you go.
Go marshall section. And you can see shreadmaster clone dreadmaster. I think it is kind of modded version.
ianmgull
Thanks for the info. Unfortunately the link to the PCB layout is down but there is a lot of useful information there nonetheless. I might just try to put my own PCB layout together when I get some free time.
  Plan on being lucky, or have a PCB mapping of traces for debugging.
  PCB with hard to see double sided tracings, without the 'map' is a long--term-grudge to debug/modify.
ubaid88
meffcio
I made the Shredmaster recently, and unfortunately the result isn't too good. It's quiet (not sure if unity gain at all), and muddy. Changing bass and treble controls don't do much (well, treble does just a little bit more that bass, but still it doesn't help with the fatness), and the contour control makes the biggest change on the very end of potentiometer's range. Did anyone have similar issues?
This is the project I used:
http://www.mediafire.com/?n6r8cl30vw97sc9
JebemMajke
http://guitar-gear.ru/proekt/Marshall_ShredMaster/shredmaster_schem.gif
From russian web site. Killer sounding pedal. And easy to mod. Contour makes a world of difference. But you can change tone stack if you want to. Guys from barber did that with dirty bomb.
http://guitar-gear.ru/proekt/Marshall_ShredMaster/shredmaster_pcb.gif
Andre
Here's a link to a  Shredmaster PCB I designed a couple of years ago.
It's verified...by me.
J0K3RX
#8
Here ya go..
DredMaster
http://guitar-gear.ru/index.php?p=proj&id=24
ShredMaster - There is also a Sprint file to download for this one but the link is hard to see.
http://www.guitar-gear.ru/index.php?p=proj&id=26
