Alpha 16mm Right Angle Long Pins pots in Europe?
Started by carboncomp, January 21, 2013, 01:56:39 PM
carboncomp
Dose anyone know where I can get the Alpha 16mm Single Gang Audio Taper Right Angle Long Pins PC Mount pots (part number RV16AF-42-15R1-A100K) in Europe?
I ordered some from mammoth electronics 2 months ago, but they have still not shown up and the customer service is non existent!
crane
I needed the same form factor pots for Ashdown MAG300 repair. All I could find was this:
http://www.banzaimusic.com/PC-Mount-Vertical/
But as you can see - those are not "long pins". I ended up using wires to make the necessary connections.
Ice-9
I have had to order these from smallbear in USA, but would like to have a UK supplier. It can't be possible that no in the UK has these and also I use a LOT of the 9mm alphas and again, I can't find any UK suppliers. So I have to get these as well from Smallbear, problem is shipping to UK is about 14 days.
As for Banzai, even though they are just in Germany (not far from UK) I would never order from them again, they were expensive and they take well over 4 weeks to arrive.  One order for pots took over 3 months to arrive and they were in stock when I ordered.
Smallbear is good, although a little expensive for the pots in the Uk they do deliver quickly for the distance.
If anyone else knows of a good place in UK to get these , please let us know.
www.stanleyfx.co.uk
carboncomp
Im sure www.musikding.de used to sell them, but cant find them on the site now, shame as there service is top notch!
