Help with valentines day gift.
Started by pappasmurfsharem, February 05, 2013, 06:05:09 PM
pappasmurfsharem
I know this isn't exactly a stomp box but I would like to use some of the common components I have.
I want to do something like a typical "I <3 You" and put it in an enclosure with a switch.
Maybe use a 555 timer to make the words light up at different intervals, if that's possible
You guys have any ideas or good resources?
I want it to be pretty basic, not planning on getting into microcontrollers or similar.
Scruffie
A 555 & 4017 could be rigged to make a few (ten I think, think it's a decade counter) of the LEDs flash at different times, a simple dual opamp triangle LFO could be good for the heart LEDs to make it look a bit like it's beating.
digi2t
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
ultra simple 3 or 6 led chaser....put the leds under the words...voila'.
3 for i  :-* u
diffuse the leds to spread the light better by just lightly sanding the leds...scuff em up a bit.. ;)
breadboard it, and play with values...put a trim from 9v to adjust speed/brightness.
blues_mang
I have a nice heart shaped metal enclosure that I'd let go for cheap that would be perfect for this project!  :icon_cool: Let me know if you're interested.
If you ain't gots da blues in yo shoes, then you got a hole in ya soul.
pappasmurfsharem
What would be the simplest way to power roughly 22 leds with nearly full brightness using a 9v adapter
pappasmurfsharem
[quote au[quote au
thor=slacker link=topic=101263.msg894605#msg894605 date=1360617241]
This http://led.linear1.org/led.wiz is quicker than I can explain it.
That's perfect thanks!
