Accidentally ordered LNK302 IC SWITCH any practical use?
Started by pappasmurfsharem, January 23, 2013, 04:56:17 PM
pappasmurfsharem
I have no idea how this got in my cart. I wouldn't have been looking at anything similar.
I'm going to chock it up as a $1.30 wasted and throw it out, unless you guys know of something that can be done with it.
LNK302GN LNK302 IC SWITCH OFF-LINE MDCM/CCM
I'm still a little confused how it got there, hopefully it didn't replace something I actually needed, because I can't for the life of me think of what is missing from my last order.
Tony Forestiere
#2
Not to derail, BUT. Thanks Gary!!! I just learned that I can type a search keyword into Google followed by " site:diystompboxes(dot)com" and get a better indexed result!!!
This is KILLER!!! :icon_biggrin:
It could be an incredibly clever (4 pins??!) way to get a watt of low-voltage DC inside a hi-volt tube amp, for things like LFO and reverb or interface logic.
http://www.mouser.com/ds/2/328/lnk302_304-306-179954.pdf
It is far from ready-to-run, you need several caps, a coil, and special diodes, and some math.
pappasmurfsharem
Seljer
You could also is it to make negative voltage from a postive voltage (refer to "High-Side Buck Boost – Direct Feedback" in the datasheet), i.e. to get a bipolar power supply from +9V or to run pnp transistor fuzz pedals
pappasmurfsharem
Quote from: Seljer on January 24, 2013, 02:31:38 AM
Hmm that might be convenient. Would that enable it to run on a daisy chained supply with normal pedals?
The specs seem to say it needs HIGH voltage input: "..check that the minimum DC input voltage does not fall below 70 VDC at maximum load, minimum input voltage."
It isn't clear why it needs THAT much, but I can see why it mightn't like 9V.
