Bazz fuss question!
Started by skizofonik, January 26, 2013, 02:18:44 PM
skizofonik
Hello everyone! I need to know what is the input and the output based on this picture: http://i698.photobucket.com/albums/vv347/harvandheavy/fuzz-distortion/BAZZ_FUSS.jpg
As you can see I'm still pretty newbish...
Is the 1/4'' jack in the bottom left of the picture a stereo jack, and is it the input?
Same goes for the 1/4'' jack on the bottom right, is it a mono jack and is it the output?
I also would like to add an LED to this bazz fuss layout, based on this:
Is it possible?
brett
Hi
that all seems correct :
A plug into the stereo jack (input) connects the ground for the power supply (it's not drawn like a stereo switch, which might have confused you).
When the stompswitch is 'on' the V+ flows via the 2.2k to the led.
Out is a mono jack (could be a stereo, too, without affecting anything).
cheers
Brett Robinson
