fx looper update & questions
Started by stirfoo, February 12, 2013, 03:04:14 AM
stirfoo
I'm making a bit of progress on my fx looper. I got an Arduino Uno and started fiddling with it. I've got pretty much all of the logic working on a breadboard. I understand the logic. It's just moving combinations of 1's and 0's around. I'm not so confident when it comes to analog signal routing.
I've drawn up a couple of schematics for the loop and output select relays. The first is pretty big for clarity.
My question is about grounding. From what I've been reading I should keep the signal ground (PGND on the drawings) separate from the logic circuit ground. I think I have that okay on the drawings but what type of cable should I use? How should I physically route the signal wires? It's going to be a lot of short run connections. But the send/return lines might be kinda of long depending on the distance to the relay. I think I'll probably stack each send/return jack pair vertically.
Also on the output relay drawing, both amps will share the same ground. Is this going to cause problems?
Oh, while I'm at it. Where is a good place to get SPDT stomp switches? I'll need 16 of them. I've found a few on line. Seems like around $3 each.
