My new circuit - World Ender Trumpet Fuzz
Started by timd, February 20, 2013, 05:14:06 PM
stonerbox
There is nothing more to be said or to be done tonight, so hand me over my violin and let us try to forget for half an hour the miserable weather and the still more miserable ways of our fellowmen. - Holmes
timd
I have 2 4046 chips, and I was breadboarding another one of these, and couldn't get the output from pin 7 like in the schematic. I did have output on other pins though. Has anyone else tried this? I'm wondering if I have a bad second 4046 chip?
earthtonesaudio
timd
The other day after removing power from the circuit, there was this really great sound that went from a high to low pitch very quickly - almost like a "death jingle" from an old video game. So, I rigged up a momentary switch to the positive wire from the power supply and it worked great: play for awhile, them press the switch and get the jingle. Cool stuff. The issue is that today, it is not working at all no matter what I do. The circuit is fine but no "jingle" when power is removed. Any thoughts?
petey twofinger
how about the sound an echo chip makes when it totally bottoms out , ever try that one tim ?
put a cds cell for the delay time on a pt2399 , get it feeding back a bit , then completely cover the delay time cds cell and hold it there ...
i had 3 p.a.'s on the volvo , under the hood . cds cells on the dash for the echo and a few circuit bent toys inside the console with switches  , and a casio vlone on cds mounted to the top of the the dash . i collected horns from the junk yard for years , we ended up with 13 sirens and horns including the 3 pa horns .
coga p.a. ( sampler type )  goin thru the delay , well actually it was a dano flange into a telephone style pitch shifter voice box , into the echo unit to the pa . i had a ton of power supply stuff ,  alil mini mixer , extra amps under the passenger seat . i speant a few summers doing all of it , and really pissed of the neighbors while testing it . i really wanted train horns but ... i had rca inputs next top the radio too . we used to plug in the speak and math or whatever and run thru stuff at stop lights , while trying to keep a straight face . then raise the speed / rate as we would accellerate , man we got some looks , folks would be thinking " some thing is really wrong with that old volvo ... "
my wife used to get a lil miffed about all this ... the kids and i enjoyed it quite a bit though .
sorry to hijack , i get sentimental sometimes . all that stuff axcept the flanger is still in the car , but my kid blew the motor and a lot of the stuff just aint workin now ... its prolly a good thing we arent neighbors , we would end up collaborating and getting arrested or fighting over toys at the local thrift store !
im learning , we'll thats what i keep telling myself
timd
Quote from: petey twofinger on February 27, 2013, 01:22:39 AM
Very true! I like my thrift store hack experiements too much! I wonder about using a momentary stomp on a pt2399 circuit...Say you had a pot that controlled the echo time off pin 6 and then rigged that up to a momentary switch to cut out the resistor (pot) to pin 6....I wonder if you could get a cool echo trail while you held the switch down...
petey twofinger
i have always removed that resistor . when ever i mod pt2399 i remove 3 resistors and then substitute them with pots . with the pot in place i feel the resistor is completely redundant . if you choose to leave the resistor in place it will not be able to FULLY glitch out but this comes with a price . -
looking at the datasheet it has a chart that shows what the delay time will be with different values of resistors .
the last entry or minimum delay time 32 milliseconds with a .5 ohm resistor or something , then for the max delay time 342 ms (ha) it is like  27.6k or some value resistor , i cant remember now .
what happends if you do not use a resistor and just cut in a pot is something like this . lets say that you turn the unit on and the last time that you used it you had the pot set on max delay time OR minimum . when you turn it on  with these " improper amounts of resistance it will not echo at all . then you have to shut it off , adjust the pot , turn it on again and then you have echo . so if one was building this for resale or wanted it more fool proof , i would think utilizing a bypass switch for that timing resistor that is stock would be the best . call that switch " delay time expander , or glitch or whatever ... it is frustrating , because i didnt realize this and just hacked all the stuff , removing the resistors and cutting in the pots .
my favorite pt2399 is a hanna montanna , in a mini cigar box , just under a shelf in my work area . it is modded for delay time  , feedback or repeats , then there is a level control too . it is attached to a "mixer" for my satellite radio / mp3 and it powers a "nice" book shelf speaker from goodwill . i have to constantly tweak the echo time , if its set long but i enjoy it .
how about making an led blinker circuit and have the blinky led by the delay time photocell . get a voice changer , put the mic element in a tube with a mini speaker or ear bud at one end . satans slide whistle ...
i wonder if a single cds could work on a chip oscillator  for pitch AND a pt2 chip for the delay time , then go with a dino segovis slide synth style controler .
what is really odd is the pink barbie guitar that looks like the hanna montanna , it also has a mic input and echo knob , but when you open those they have a different layout , massive pcb , amd it seems to me the echo is contained in a black blob :( which i spose could be :) depending on how few components one needs when repurposing said blob .
timd
The bypass switch idea seems good. I had the Barbie circuit too and didn't have a lot of fun with it trying to make it an echo, so I made a dirty tremolo with it:
Sorry for the bad video quality - that was my old camera. The Hannahs come in 3 different styles from what I've seen - 2 have echo and 1 doesn't. Besides the resistor from pin 6, what 2 others are you removing for pots? I usually remove the pin 6 one for a pot, add a master volume, and try to find a creative bend or two for the other pots.
