Adding bands to Parametric EQ
Started by iheartleaven, February 26, 2013, 05:57:57 PM
iheartleaven
Hello! I would like to build this Japanese parametric EQ circuit, but add one or two additional bands. Here's my question: Is it more sensible to add additional bands as complete EQ blocks in series, or to stack additional filters in parallel before the mixing op-amp as in R.G.'s Basic Parametric EQ?
It seems the stacking approach would involve using only 3/4 of a TL074 for each new band, and sending the output of all filter sections to pin 5 of the original TL074. Is that nuts? Is there any reason, other than parts count, that it would be better? I've included edited schematics showing how I imagine each approach would be hooked up. I included a coupling cap between stages in the "series" configuration. If you see any glaring problems, please let me know.
Original Circuit:
R.G.'s Parametric EQ:
"Stacked"
Versus "Series"
I don't think that will work for *this* design.
Your "series" should work. You do not need the added coupling caps.
iheartleaven
Awesome, I'll get breadboarding. Thanks for responding!
Thecomedian
Im thinking the "coupling" cap is meant to disconnect the DC of the first circuit from the second, basically like plugging the previous one as a complete pedal into a "parametric EQ pedal". Only the AC would be going to the next pedal, or in this case the next stage.
Is that what you were thinking, op?
If I can solve the problem for someone else, I've learned valuable skill and information that pays me back for helping someone else.
Look at how IC1 couples to IC2.
*All* the stages are DC biased at V/2, and have unity gain at DC. Therefore they can be direct connected.
Thecomedian
Thats true. I've been over that before. The idea of isolated "stacks" as a modular system, but if it all runs off the same battery anyway, decouplers wouldn't really do anything.
