An easy trem+vibrato - looking for options
Started by Mark Hammer, October 12, 2012, 11:32:12 AM
I picked up a small Garnet solid-state amp a few years ago at a curb on garbage day, and gutted it, to re-use the nicely-tolexed cab and amp chassis (w/transformer)***.  I recently picked up a nice 10" alnico Weber speaker that fits perfectly in the cab, and I painted and re-legended the chassis, popping in a few extra holes.
The intent is a basic all-in-one amp of around 10W or so.  No overdrive.  Just treble/bass, long/medium/short echo settings courtesy of a Rebote 2.5, and speed/depth for tremolo/vibrato, with only one selectable at a time.  Any other things can be inserted ahead of the amp.  And, as luck would have it, the cab is exactly the same dimensions as my tweed Princeton, so I can park them side by side.
So, I'm going through all my schematics, looking for something that could provide basic pitch-wobble vibrato function, and be easily amended to provide tremolo with a DPDT toggle.  At present, the best candidate seems to be a modded Phase 45, that uses an additional stage, borrowed from the EA tremolo.  The P45's LFO would modulate the drain/source resistance of a pair of 2N5952s (plenty of matched pairs sitting in the bin) plus a drain/ground FET, as in the EA trem, to set and vary the gain of a single-transistor stage.  I either pick the output of the P45 (wet only) or the output of the EA gain stage.
A couple of questions emerge from this starting point:
1) Is there a better or more convenient platform to achieve what I'm aiming for?  Doesn't need to be the world's greatest trem or vibrato- I've got oodles of other pedals to do that.  I'm looking for simple, convenient, functional.
2) If what I described IS a solid platform to work from, do I need to use the same FETs for the P45 and EA trem sections, or could I mindlessly use 5952s for the vibrato and a J201 for the trem?
3) If a single curent-limiting pot from the P45's LFO (in place of the 3M9 resistor) likely to be able to produce pleasing and useful ranges of depth for BOTH functions?  I'm thinking that a 100k rev-log speed pot would be appropriate, since neither vibrato or tremolo are particularly audible at slow phase-sweep speeds.  However,  I suspect the depth range for pleasing vibrato and tremolo is not identical.
I'm open to ideas.
***Would have brought the amp back to life but I could never get my hands on a schem for it anywhere.  Still have the board though, if anyone wants it.
midwayfair
tca
Hi, do you have any ref for the circuit of that amp? I've been searching the web with no results, yet!
Cheers.
I suspect, not luck, but simple copy-cat. At the time, Fenders going into Canada paid an import duty. Gar saw he could build similar stuff, even in small quantity, sell it locally for less than a Fender, *and* proudly Canadian. While Tweed Princeton is pre-Transistor, it is a good size so why make new jigs?
No opinion on your question. I'd breadboard it trying more and less knobs and various FETs before doing the final build.
