Hybrid Fuzz Face - stability?
Started by kwtsos, March 15, 2013, 10:23:28 AM
kwtsos
Hi everyone, great forum!
I am about to build a Fuzz Face. I mostly like the tone of the germanium ones but I really dont wanna have the stability issues with temperature, you know, hot days, gigs under the sun, etc.. ::)
If I build a hybrid one (Q1-silicon, Q2-germanium), will it be stable enough? If not, can I use the "reverse-bias germanium diode" to stabilise my germanium transistor?
All in all, I need a really stable Fuzz with at least one germanium transistor.. Is hybrid the solution?
Thank you guys!
Johan
Both your ideas are valid and has ben tried before.do a forum search for easy face
J
DON'T PANIC
joegagan
if you have a good germ, the easyface recipe will give you pretty good stability.
mac
The problematic transistor is Q1.
Q2 gain and leakage has little impact on thermal runaway. You can use a leaky AC1xx at Q2.
If you want a silicon with high internal capacitance and low gain try BD175 or BD237.
mac
midwayfair
These are awesome in Q1:
http://www.smallbearelec.com/servlet/Detail?no=1263
They also work great as Q2 in buzzarounds and benders.
I use a hybrid fuzzface on my board; it's very, very stable.
joegagan
midway, are you using an NPN germ for Q2?
the 2n5134 looks pretty but i think it is NPN, right?
LucifersTrip
if you use silicon Q1 and one of those "zero" leakage ge modern Russian's (1T308, etc) for Q2, it'll be pretty damn stable for a hybrid FF...but, those Russians won't give you the "softness" that other ge's can
always think outside the box
mac
Quote from: LucifersTrip on March 15, 2013, 04:19:14 PM
If they are zero leakage, go for a Ge FF :)
mac
LucifersTrip
I put "zero" in quotes because they are not really zero leakage. They measure 0 on the Peak Atalas. in reality, they are very low, usually 50uA and under.
mac
I have some Toshibas 2sb49/52/53 that leak less than 20ua.
They are too bright for a FF IMHO, but they are less sensitive to temp changes. IIRC they move between 4.0v(winter) and 5.5v(summer).
mac
