Best Simulation Software
Started by jishnudg, March 13, 2013, 05:44:41 AM
jishnudg
So in an effort to cut down on breadboard casualties, I've decided to do a simulation of every design I make before prototyping....what is the best dedicated software for audio electronics simulation - cost no object, I'd rather invest in this than spend hours over non working perf layouts. Any suggestions?
Regards,
J.
radio
Hi
Do you have a tablet? In this case I d advice'every circuit'.
It is dead easy to enter the schematic(part select ->rotate to correct orientation->position part correctly,change value if needed)
After your schematic is drawn complete save it to a new name,then you may start the circuit after having an input signal
lets say 500Hz at 100mV for guitar. You get an alert if you forgot to ground some part of the circuit however sometimes you
notice one transistor gets sinewave in,but none out. So the bias is not correct ,however this starts to show also the limits of
the program. You can't select a AC128 or a BC550. You just have a generic NPN or PNP type! And via parameters you can change
obscure values of the transistor like base to emiter resistance that you won't find in a datasheet.(Maybe calculate at some voltage)
So in my opinion ,I can just use this specific program first to very easily draw a schematic with easy available parts.
Simulation wise it works quit correctly even for example a tube sound fuzz with inverters is rendered correctly. But it does in
no way replace a breadboard . Probable PC software like LT-spice give more accurate results AND more needed parameters.
Hope that helped!
Regards JM
Keep on soldering!
And don t burn fingers!
