Delay pedal problems.
Started by VolksWilliam, March 15, 2013, 10:57:28 AM
VolksWilliam
I've recently built a delay pedal and have a couple problems I hope u guys can help me with.
1. When on the pedal boost my dry and wet signal. I'm thinking I just need to add a resistor somewhere but not sure where. Output to the switch maybe?
2. I like the true bypas but I don't like that it turns off my repeats when I switch it off. If I connect the output of the effect to the bypass side of my switch would that let me repeats carry out even when I turn the pedal off?
Thanks guys!
armdnrdy
Quote from: VolksWilliam on March 15, 2013, 10:57:28 AM
Which delay pedal?
No, that will keep the effect on in effect and bypass mode. You need to add another switch for "repeat tails"
Thanks guys!
VolksWilliam
Quote from: armdnrdy on March 15, 2013, 11:16:01 AM
Which delay pedal?
It's a pt2399 based lofi delay.
I just want to cut the volume of the entire pedal only when it's on. I'm using a 3pdt tru bypass switch.
I was assuming that if I didn't give the pedal input but gave it output when off it would have trails. How else would I do that?
Thanks Armd!
armdnrdy
#3
Quote from: VolksWilliam on March 15, 2013, 12:55:14 PM
Thanks Armd!
Which pt2399 based lofi design? If you post a schematic or a link to one....we can help.
Here is a link to the "Small Time" one of Merlin's creations.
http://www.diystompboxes.com/smfforum/index.php?topic=95632.0
I believe that this design leaves the "tails" feature on all of the time. Read this thread and you will come across switching the tails in and out.
