Wiring a switch question, dual pedal changing order of pedals
Started by tomnottom, May 18, 2013, 09:22:13 AM
tomnottom
I built a pedal using this wiring diagram my question is how and what would I use to be able to switch the order the pedals work. Right now it's BSIAB2 into booster but I would like to be able also have it go to booster into BSIAB2.
nocentelli
http://www.beavisaudio.com/projects/Looper-Switcher/Effect-Order-Switcher-Wiring-Diagram.png
Treat the two sets of send + return jack connections as connections direct to the inputs + outputs of you two bypass switches. You can use a 3PDT for the first 3 columns to switch the order and not have a LED - It's not strictly necesssary if you use a toggle, you can visually check the order from the toggle position.
