BBE sonic stomp issue
Started by JebemMajke, April 14, 2013, 01:52:20 PM
JebemMajke
I;ve used madbean's layout
http://www.madbeanpedals.com/projects/Bloviator/docs/Bloviator.pdf
It doesn't work. Like at all. No sound, dead :D
Here are my voltages
IC1 ( tl082 )
1 4.1
2 4.1
3. 3.73
4 0
5 4.1
6 4.1
7 4.13
8 8.24
Ic2 ( tl084 )
1 4.1
2 4.1
3 3.74
4.8.24
5 4.1
6 4.1
7 4.1
8 4.1
9 4.1
10 4.1
11 0
12 4.1
13 4.1
14 4.1
IC3 ( tl081 )
1 0.1
2 4.1
3 1.44
4 0
5 0.13
6 4.1
7 8.24
8 0
JebemMajke
Got it to work. It's really bassy. And kind of lowers the overall volume level. A bit, but it does. I;m using it in front of my amp. Because I don't have the send return jack's. And it kills a lot of hum that. It's great for adding some balls to the sound, and definition as well. It sucks when i switch my pickups to single coil.
JebemMajke
I must have done something wrong here ... it's muddy as hell and it has volume decrease. And it has zero sound when switched to single coils ... any help?
Keppy
Double-check pin 3 of the first two ICs. that measurement looks wrong, because if those pins really were at 3.73-3.74v then pins 1 & 2 should also be 3.73-3.74v. I don't know what could cause that difference if it's real, unless the ICs are in the wrong orientation or something like that.
JebemMajke
C6 was 100n instead of 100p :D
Works great now.
