Wah Wiring Needs Verified!
Started by soupbone, April 24, 2013, 08:35:46 PM
soupbone
I've got a U.S. Made Vox V847 Wah.I need some verification from this diagram for wiring it up with a 3pdt switch,LED,and D.C. Jack.I uploaded some gut-shots of the inside of the pedal.Also,i added the Wiring Layout i found(Maybe found it on here?),and Schematic.Just need verification that this wiring layout is correct.Thanks in advance!Here's the link to the pics; http://s1143.photobucket.com/user/soupbone71/library/Vox%20V847%20U%20S%20Made%20Wah%20Pics%20Wiring%20and%20Schematic?sort=2&page=1
soupbone
I've  talked  to  a  couple  of  people,and  they  said  this  wiring  looks  it  will  work.Just  need  some  confirmation  from  somebody :)
soupbone
Quote from: soupbone on April 25, 2013, 04:08:00 AM
Uhh...Yello?
Keppy
That's the wiring in my modded Vox wah, minus the LED. Works fine.
On mine, it's pretty noisy when using a wall wart rather than a battery. I've been meaning to wire a resistor in series on the positive supply voltage to try and fix that.
soupbone
Quote from: Keppy on April 26, 2013, 11:31:13 PM
Thanks Keppy!If you want,i know a way of how to install a filter.P.M. me your your email,and i'll send it to you.
