Tube Screamer - Doesn't Work - Debug Help Requested
Started by angelkiller, March 14, 2013, 07:46:01 PM
The voltages on the first transistor, I assume this is Q1, almost look like it's in backwards. I would check this, it should be oriented the opposite way to Q2.
angelkiller
Quote from: aron on May 03, 2013, 04:58:00 PM
Do you get any sound on pin 1?
No sound on pin 1. Only 3.
Quote from: pakrat on May 03, 2013, 05:05:15 PM
I just completed a tonepad tube screamer that works properly. I can post my voltages if anyone thinks it would help.
That would be fantastic!  ;D
Quote from: slacker on May 04, 2013, 11:17:36 AM
Thanks, the transistors are in fact facing opposite directions. ie the one curves toward the pots, and the other curves toward the bottom of the board opposite of the pots.
angelkiller
Quote from: R O Tiree on May 04, 2013, 06:35:06 AM
See if you can upload high-definition, well-focused pictures of both sides of the board. Keen eyes might be able to spot either misplaced components or potential problems with solder joints.
10 pictures: http://imgur.com/a/RQJ5E
It's bad guys, I'm sorry. My soldering iron is a wood burner... with a soldering tip.... yeah. A proper multimeter and soldering iron are on my list of things I need. But currently, it's the only I have.
phizone
From those pictures, both transistors appear to be in backwards. In http://imgur.com/a/RQJ5E#4 you can see what the orientation of the transistor on the right should be under the socket.
angelkiller
Quote from: phizone on May 05, 2013, 04:54:40 PM
Fixed.  :icon_redface:
Still can't get audio from IC pin 3 to IC pin 1. All I get on pin 1 is a little static. Maybe the IC is bad? Is there a way to test for this?
pakrat
I'm sorry angelkiller, I didn't see that you wanted voltages. I'll post them later tonight.
pakrat
Ok, here are my voltages:
Supply voltage is 9.50V
Q1 (2N3904)
E  3.58
B  3.83
C  9.50
Q2 (2N3904)
E  3.58
B  4.03
C  9.50
IC1 (JRC4558D)
1  4.70
2  4.78
3  4.71
4  0.00
5  4.69
6  4.66
7  4.65
8  9.50
I hope this helps!
