DIY Pedal Board Power Supply ( Finished !! )
Started by HOTTUBES, May 28, 2013, 02:51:21 AM
HOTTUBES
I had some Help from a few member's of this forum on the best way to build my own power supply etc ...
I just thought i would say Thanks to all who posted  !! :)
I play tested it tonight , and it's dead quiet  !!   :icon_mrgreen:
Here it is ... it's not super fancy , but it's really all i need !
jimilee
Rethfing
Very clean looking, but also very big enclosure :) I guess you could fit that in 1590B! Do you have any PCB layouts and schematics for this?
crane
SMPS + linear stabilizer -- I also use that idea. The difference is that I am a little bit afraid from 220VAC in metal enclosure close to pedal outputs that's why my 12V smps wallwart stays as is and feeds the "box" with 7809 inside. Features:
x) total current about 1A (with current wallwart, theoretically can go up to 1.5A)
x) 10 outputs
x) big electrolytic cap + extra cap soldered directly at each output
x) switch
x) status led
x) compact size.
tubegeek
Quote from: crane on May 28, 2013, 04:10:58 PMThe difference is that I am a little bit afraid from 220VAC in metal enclosure close to pedal outputs
Don't be afraid: just connect the ground pin of the power cord securely to the metal box. I VERY MUCH HOPE that HOTTUBES wired his like that - I can't tell from the photo exactly. Use a screw that doesn't attach to anything else, and give it a lock washer and a ring terminal. Solder a (green) wire from the ring terminal to the ground pin of the AC cord connector.
Henry89789
Does anyone have a schematic for a power supply like this one?  Thanks.
armdnrdy
HOTTUBES
Quote from: tubegeek on May 28, 2013, 07:02:32 PM
Yes , i did ground the enclosure itself , it was one of the last things i did , and i had taken the pics before etc etc ....
HOTTUBES
x) 10 outputs
x) switch
x) status led
x) compact size.
I like yours too , very small & compact !!
The enclosure i used , i had sitting around for another project , so i just used that one ...
HOTTUBES
N
Quote from: jimilee on May 28, 2013, 11:20:26 AM
Looks great, is that a tall 125b enclosure?
It was a 1590D Hammond  !!!
I like the bigger size .....
