want to add a led and true bypass to black ross phaser
Started by lownotemaster, July 03, 2013, 11:03:13 AM
lownotemaster
I'm a newb. But I would like to add a true bypass and a LED to a vintage black Ross phased. I have an idea but I'm not quite sure, please tell me if I'm wrong. I just need to run a 9v leg from the power, add a 2.2k-5k resistor before the LED and connect the other end to the switch. I haven't check to see what switch is in it at present, to be sure its not true bypass. Can someone steer me in the right direction? Thanks.
Heat up the irons and crank up the Floyd!
this is a cool guide. using a 3pdt switch for led on/off  and true bypass.
http://gaussmarkov.net/wordpress/thoughts/wiring-up-a-1590b/
find your pcb in/out and your sorted. :)
lownotemaster
Thanks. I'll get right on it right after I take this wild bunch of screaming kids to the beach. All I want to do is crank up my iron, turn up the Floyd and mod some pedals!
