Signal Routing Center Suggestions
Started by 0ron124, August 14, 2013, 08:22:41 PM
0ron124
Hi guys,
So I am working on building a new pedalboard from scratch with a built-in signal routing center, power supply, and noise suppressor (ISP moved to another box inside a sheet metal enclosure). Here's my very rough layout for the signal path currently I only have one loop in place but there will be essentially two more, one for another pedal chain and the other for the ISP Decimator. Hopefully you guys get what I'm trying to do, Google Docs just doesn't allow to add more anchor points unfortunately so it may be a little bit funky.
The three toggle switches will be used to move an entire pedal chain before the preamp on the amp or before the poweramp. I'm hoping to make these pedal chains completely independent of the other except I would like to have Loop 1 always come before loop 2 if they are both set to the same location in the chain.
Please let me know if you have any suggestions or comments on it thus far.
https://docs.google.com/drawings/d/1jmTpOg5OpBqPG9Em2HvtedzqOHuYLnU3TyDHltQLuUw/edit
