Switchless wah?
Started by bancika, March 26, 2006, 06:19:32 PM
jimilee
The Dunlop bass Wah is a rock forward clickless engage, but it is spring loaded so if I take my foot off of it, it will automatically return to the heel position. I like it for bass pretty good, but I imagine guitar players would get pretty annoyed with it quickly.
victor nery
#21
Greetings,
Thank you all for the replies. I really learn a lot reading your posts. About the switching scheme, I plan to use a resistor and a momentary switch in place of the led ldr arrangement. I traced a schematic based on what I've read in this post. Is it correct? I didn't trace the relay connections only the one that goes to pin 1. Should I add a transistor after the inverter to drive the relay or is it enough to drive it and what value should be R2 in this scheme?
Cheers
"Do what thou wilt shall be the whole law!"
joegagan
Quote from: R.G. on July 17, 2013, 10:04:47 PM
tempted to do it with a magnet and a reed switch.
hmmm, nice idea. 8 :) :icon_idea:
CodeMonk
What about something like...
Mount rubber pad on a piece of sheet metal (Some sort of spring steel).
Have it so it is ever so slightly arced, so that when you step on it, its goes flat.
Then mount a tactile switch underneath it (similar to R.G.'s pancake switch?) ?
Just off the top of my head.
jimilee
Here is another idea, a local fellow started modding wahs  by mounting a momentary switch on the treadle, so it would activate the wah anytime you put your foot on it at any position anytime you wanted to use it. I just remembered that. It should be a less complicated and cheaper mod.
victor nery
Greetings,
My point is to have the same mechanism as in the bad horsie (with delay off adjustment) + relay bypass as suggested in this topic but using a resistor and a momentary switch to bypass it emulating the led/ldr. Doubts are about some values and the need/no need to add some extra components.
