Crunch Box V2 Presence / Output Wiring
Started by chumbox, July 22, 2013, 02:29:13 AM
chumbox
Will this work (bottom wire says 'out'):
For this schematic:
http://1.bp.blogspot.com/-0zGoV3jSwJs/TyKL3gQsCqI/AAAAAAAAAvs/s1ZwxhpG0WU/s1600/miaudiodistv2rx7.jpg
I understand everything just needs to get to ground somewhere.  I just can't work out in my head if putting the cap between the two grounds of the pots will cause an issue?
Thanks all :)
The bottom (right as drawn) terminal of "Presence" pot is not "a ground" by itself. With the cap to ground, it is not-groundy for bass, groundy for treble, which makes it some kind of tone control.
The drawing will work.
chumbox
Thanks PRR. Great explanation, understand the logic. Thanks so much.
