tl072
Started by newperson, June 25, 2012, 03:12:49 AM
newperson
Hi,
What is the smallest circuit that could be build to use as a test circuit for a TL072 IC?
gregwbush
The simplest circuit i have built with a tl072 (dual op amp) uses just one of the op amps and is the AMZ op amp buffer
http://www.muzique.com/news/opamp-buffer-layout/
That'll tell you if it works... (assuming that's what you mean by test circuit... if not, please elaborate!)
newperson
Thanks for the reply.  I think I would need something using both sides of the amp to make sure the ICs fully work.  And yes this is what I am looking for in a 'test circuit.'
LucifersTrip
can't you just hook up the same circuit separately for both sides of the opamp?
always think outside the box
gregwbush
It would be very unlikely that if the chip works, one half of it doesn't, but i understand you want peace of mind  ;)
You could do as LucifersTrip suggests and build a dual buffer
As it happens, i did a vero (strip-board) layout some time ago for one... I'm just labeling components better for you now, and i'll post it....
Ok here it is
jk-fm
Triangle oscillator! 3 resistors, 1 cap, + 2 resistors for vref
gregwbush
you can plug a guitar into mine  ;D
pufferton
Quote from: gregwbush on June 25, 2012, 07:49:21 PM
Ok here it is
has this build been tested and verified? im trying to build it and running into grounding issues...(continues popping and LED flashes) but not seeing any issues with it...
psychedelicfish
Quote from: pufferton on August 11, 2013, 09:30:28 PM
The layout looks perfectly fine to me. Are you sure you've wired everything correctly and that there are no solder bridges, badly cut traces etc.? Popping might suggest a backwards electrolytic capacitor, I would recommend checking you have all of them correctly oriented
If at first you don't succeed... use bigger transistors!
pufferton
just triple checked everything...had some issues, fixed them but still the same problem....would it do this if i had a bad component? i removed the board from the chain and i get 9v from the dc jack and LED shines steady. no 1/4" jacks are hooked as of right now.  as soon as i wire everything back up its flashes and i get 1-2v reading.
pufferton
Quote from: psychedelicfish on August 12, 2013, 12:36:01 AM
http://postimg.org/gallery/alul4cjk/
so it looks extreamly messy cause i have taken it apart 4-5 times....
any idea??
Tangentsoft's IC tester. Can be built to test single, dual or quad opamps.
http://tangentsoft.net/elec/opamp-tester.html
stallik
Hey! A duplicate post... Ic still looks to be upside down
pufferton
Quote from: stallik on August 13, 2013, 06:16:12 PM
sorry about the duplicate. i was dealing with two different things and the problems converged. i will try switching it tomorrow. thanks so much for your help!!
stallik
No worries, I thought I was having a de ja vu moment - I've had them before
