Catalinbread Pareidolia help needed
Started by Kimster, November 04, 2012, 03:24:16 AM
Kimster
Hi!
I just finished building a Catalinbread Pareidolia based on a vero layout from Sabrotone www.sabrotone.com/?p=2528
It works just fine, but it is very sensitive for what comes after it in the chain. If I put anything between it and my amplifier (classic 30) then it gets very bright and harsh. It also feels like there is a volume raise. I also tried putting a buffer after it, but it results in the same thing. It sounds best if it is the last pedal in the chain, but still it is a little bright. When searching on the net after solutions I found out that the early units from Catalinbread had this issue and that makes me think that the vero layout is from an old unit. Catalinbread has made a fix for this but I don´t know what they did and I don´t know how to find a solution for this. Anyone got any ideas?
Kimster
roseblood11
That's interesting! I always said that my clone (same layout as yours) doesn't sound exactly like the pedals in some youtube demos. I think the sweep is too wide, the treble side is too bright and the bass side is too low/muddy. Even if I use a similar setup as in Catalinbreads demos (Strat or Les Paul, Pareidolia, modded Blues Jr (similar to their Princeton Reverb), it doesn't sound 100% correct. The treble side of the sweep is too harsh and the bass side causes the amp to distort even if it's set to a totally clean sound.
Kimster
Hi again!
I checked the layout again and found one odd thing. It is the wiring to the vol pot. It says to connect the output from the circuit to lug 2 and the output from the pedal to lug 3. I changed this and it made a huge difference. I also added a 1nF cap over leg 1 and 3 to get rid of some of the harshness and now it plays really nice. Check if your pedal (Roseblood11) is wired the same way.
dulcetpine
Alright, this is driving me nuts.
My first attempt at this build didn't work properly- though everything lit up nice but it was overly harsh and had no depth. I also had odd voltage readings and decided to cut a new vero board and start from scratch. In doing so I decided to de-solder all the components from the previous build and test them individually to see if I could find a faulty component and all I found was that I had an extra 1M resistor in there on one too few 10K resistors... so I figured that was the cause of my issues and the reason why I couldn't find what was wrong at first glance.
Now the pedal is working great but the LED's do not light up. I can't figure out why and maybe I am having a brain fart but by all indication they SHOULD work because I get fluctuating voltage readings from 1v-4v with speed intervals that vary with the Rate pot. My first thought is that this could be a grounding issue with the footswitch... any other thoughts? (Note that I verified all components and solder points as accurate and hot).  I am using two 5mm LED's with the (-) of LED 1 > (-) LED 2 > Footswitch.  When I built this the first time the LED's worked perfectly with this arrangement.
I really want to get this puppy on my board.
