LED/pedal turns on when stomped without input being plugged in
Started by ajstahl, August 19, 2013, 02:05:46 AM
DIMstompboxes
Are you using battery or power supply?
Use only the battery so helper can analyze and take out some variable.... OR  power supply first later the battery. .
ajstahl
Haven't even attempted using a power supply yet, have only used a battery.
Sorry to be such a pain with something pretty tedious
DIMstompboxes
No no no it's okey, I find this forum members great and grateful to help, I like it here you know.
Now you try the power supply and tell us then.
There must be something wrong with how your battery is connected. If it was connected correctly then the LED could not come on with nothing in the input jack.
Check that the black wire from the battery snap is connected to the ring connection of the jack. If you have a meter check that there is no continuity between the ring of the jack and any where else.
DIMstompboxes
Quote from: slacker on August 27, 2013, 08:51:06 AM
Slacker is right, maybe there's a short in the input jack and also why no sound when it is ON. We're near I can feel it.
pappasmurfsharem
This isn't the best way and of course there may be variance in your spacing but can't you do something like this?
ajstahl
To try make sure it wasn't the battery i've pulled it out completely. Even with just using the power jack it STILL happens!
That is normal, using the DC jack the pedal will work with nothing in the input jack. The input jack only disconnects the battery when nothing is plugged in, it doesn't disconnect power from the DC jack.
Something is wrong with the connection of the black wire from your battery snap. It's either connected to the wrong place on the input jack or something is causing it to be shorted out to the case or to ground in some way.
If it was connected correctly then with nothing in the input jack the negative of the battery (the black wire) is not connected to ground so no current can flow from the battery so the LED cannot turn on.
Do you have multimeter?
DIMstompboxes
What wire color is your input TIP? is it RED? if it is why is your 3pdt jumper wire is BLACK for the input? am I wrong? difficult to traced.
ajstahl
OK! I pulled the battery clip and now it goes fine!
Thanks so much for every ones help, so glad the thing is finally finished with no issues!
DIMstompboxes
Quote from: ajstahl on August 31, 2013, 11:19:54 PM
Dang that battery clip mess things up, glad to see it's working now.
