Headphone belt-pack / amp with built in limiter? Do-able?
Started by therealfindo, October 01, 2013, 04:54:06 PM
therealfindo
I guess this is not strictly a Stompbox question.. so sorry if this is the wrong place...
I was thinking about a belt pack for my In-Ear-Monitors, which I use with a cable to an Aviom mixer, with some kind of limiter to protect my ears from unexpected loud noises.. anyone got any ideas of how I might do this?
Cheers.
It likely do-able, but I suspect it can be done better at the transmitter end than at the receiver end.
tombaker
Quote from: Mark Hammer on October 01, 2013, 06:00:13 PM
+1 on this.
Blue Box, Harmonic Perculator, Brian May Treble Boost, Klon Vero, Fuzz Face Germ/Sili, Echo Base Delay, CS-3 Monte Allums Mod, JLM 1290 Mic Pres, JLM Mono Mic Pres, Engineer's Thumb, A/B/C & A/B boxes, Tiny Giant Amp, Microamp
therealfindo
I'm not using a transmitter or reciever - I'm coming cabled out of the personal mixer. In any case I need to make some kind of belt pack, because the cable on the IEMs only reaches a little past my waist..
mistahead
The 'phones are a WIRED receiver.
The device pushing signal to them is the transmitter.
Adjust the signal at the output of the mixer, not on your hip.
therealfindo
Quote from: mistahead on October 02, 2013, 02:22:48 AM
Sorry, I assumed you were talking about wireless..
The issue isn't the normal output - yes, I set that on the mixer. I'm just wondering about a built in limiter to stop unexpected loud noises - such as happened in a rehearsal recently, despite the mixer being set at a comfortable level. The question is what a limiter circuit would look like. (You don't have to think it necessary ;) )
GibsonGM
At its most simple, it would look like a clipping circuit found in our distortion pedals.  That is where diode clipping came from :o)   Diodes to ground, often biased so you can adjust the threshold of clipping.
Found this in 10 seconds - not very fancy, but it's the basis of all this stuff.   Some good info in there, actually. Enjoy!
http://www.261.gr/limiters.html
therealfindo
Quote from: GibsonGM on October 02, 2013, 08:22:38 AM
Nice little chunk of info there.  Thanks.  It's not at all something I'd recommend for the hypothesized belt-pack, but still useful info for other circumstances and nicely illustrated.
mistahead
Not bad idea there... if you're just trying to protect your hearing by removing peaks in the monitors hard clipping will do the trick.
You could easily put some anti-parallel diodes in between a male and female headphone jack pair, just measure the threshold you want to cap manually (ie turn it up with a meter watching) and pick the diodes for +/- that threshold (the audio signal is AC), I'm not seeing how much you gain in this use by adding a resistor/soft clippers too but I could be missing the point.
With my usual ghetto style I can imagine knocking up a dodgy over-simple limiter with two diodes, the above mentioned jacks and about a foot of duct tape, have ten of them in the guitar case and screw polish / L.T. reliability.
tubegeek
Quote from: Mark Hammer on October 02, 2013, 09:04:15 AM
With references, yet! Holy Cow!
