Alembic Stratoblaster
Started by soupbone, November 22, 2013, 06:13:36 AM
soupbone
I found a lyout for the Alembic Stratoblaster.The only problem is i can't tell which side negative or positive on the layout.Her's the layout i found; http://stompboxed.blogspot.com/2012/04/alembic-stratoblaster-2.html.
waltk
The pad at the top-middle of the layout marked "+9V" is positive.  The pads on both sides (left and right) are negative/ground - you can see they are all connected.
...but I'm not sure that answers your question.  If that's not it, can you rephrase the question?
the empty layout in the second image has some reversed print, and the components are oriented the same as the upper image, the the lower is looking through the component side at the copper side, rather than looking at the copper side.
if that was your question, otherwise, ^+1.
" I will say no more "
soupbone
I  didn't  quite  explain my  question   right.Sorry  about  that.I  was  talking  about  the  electrolytic  caps.I  can't  tell  which  is  the  - or +  side.
Tony Forestiere
You probably can't see the slightly grey half moons on the negative side of the caps, but the positive side goes in the square pads.
LucifersTrip
always think outside the box
