Kingslayer volume issue. Help?!,!
Started by nate77, January 15, 2014, 11:07:16 PM
nate77
I've recently put together a kingslayer from madbean and everything thin works as it should OTHER than the volume is 40% lower than it should be. With everything dimed out it pushes just under unity output. Is it possible that the clean gain side of the dual gang pot isn't functioning?
