Cutting Vero and Perf Board- I cant do it!
Started by claytushaywood, March 04, 2012, 09:25:47 PM
Quote from: me
Yeah, seen some vendors selling exactly that - specifically for cutting up PCB stock.
I think I'll withdraw this daft suggestion, Rob.  Just seen the price of PCB shears at Rapid.  Hundreds of quids...   :o
stallik
Broke my last hacksaw blade so in desperation used a 2 inch masonry chisel and a club hammer. One big hit and the board parted but spent the next half hour searching for the good bit which had shot across the garage and hidden itself in all the rubbish. Nice cut though
^ +1 for style though...
@marc: yeah pricey as ..... :icon_eek:
Mmm.  Replacement blade = £135.   :o   Just don't get Kevin to whack it with his club hammer!   :icon_wink:
(BTW, @Kevin: YouTube link??   ;D )
£135...wtf..:icon_eek:
even the pcb guillotines are a joke price wise too...
i'll bid on my little table saw i think...sod it.
cutting the board is the only part of diy i despise...so anything that helps to cut a few boards easily i'm up for... 8)
Jdansti
I just tried the score and snap technique and it worked pretty well.
bwanasonic
A $10 pair of tin snips that you can get at any well equipped hardware store will do a good job.
MrStab
i just use a stanley/utility knife and cut all the way through vero in a few cuts. i used so score & snap, but i found that could be problematic sometimes, with the copper strips tearing in unwanted ways. i find it much easier to cut from the top (non-copper) side. i press down hard with my index finger as close to the blade as safely possible, so i'm applying force but staying in control. whenever i screw up, it's because i rushed it. i prefer not to sand the edges, and just lightly pick away any imperfections with my fingers, but sanding has been okay the few times i've tried it. a fresh blade can help a lot. i always alter layouts so there's a bit more leeway - i don't like having all the offboard wiring in the very last holes from the edge and it gives me extra peace of mind when cutting.
i've never really given much thought to how others go about this - it's interesting to hear everyone else's approach.
Recovered guitar player.
Electronics manufacturer.
Perrow
^he's not English he's from Liverpool... ;D
( regardless of title thread, i'm talking about PCB FR4 board cutting.)
the snips are probably ok for small boards , but i want to cut A4 widths/lengths, i would think it would crack halfway through using those...
there is a definite market for a simple and inexpensive tool for cutting pcb FR4 easily, and precisely, with no mess/dust....ive done a fair bit of research, and everything ive come across
that is for ''pcb cutting'' is ludicrously  pricey...... :icon_eek:...and i mean ludicrous..
i spoke with a guy who tried the minicraft table saw and he said it was useless, not enough power etc...so that's out now....hmmmm....
i know i would slip and cut my hands to ribbons trying this method....and then i wouldn't be able to play...kinda defeats the object really.. ::)
http://www.youtube.com/watch?v=NVegtCh_tu0
https://www.youtube.com/watch?v=uBkPX_QhRI0&feature=youtube_gdata_player
The last method he shows here looks pretty good for large pieces. Easy enough to knock something up that would do the same job using some angle iron and a few nuts and bolts.
If you're worried about slicing yourself up get down your local diy store and get some chainmail gloves :D
OSH Park, or similar. Just sayin'.  ;)
When I feel lazy and I'm about to make a big mess, I often just prop the hose from my shop vac next to the source of the mess and turn it on and leave it on until I'm done. For instance, I score F4 with a utility knife next to the shop vac input and all the toxic dust flies in the vacuum immediately. Then I snap it in the vice, easy. Then I sand the edges down, again, next to the vacuum. It works for patching walls, sanding small pieces, drilling aluminum, etc. It's a loud waste of electricity, that's all. But I got ear plugs and I'm wasting electricity all the damn time anyway...
Ice-9
I no longer use Vero or Perf, but I remember I used to just run a Stanley knife along and over the holes and on both sides of the board then just snap it. I haven't read the whole thread here so not sure if anyone else has suggested suggested method.
www.stanleyfx.co.uk
