Twin T filter as bandpass instead of notch?
Started by brett, February 16, 2014, 08:28:30 AM
brett
Hi
I'm after a bandpass filter and I'm wondering if I can use a Twin T as a pass rather than a cut.
As a notch, it's usually:
http://www.radio-electronics.com/info/circuits/rc_notch_filter/twin_t_notch_filter.php
Without thinking about it too much, I imagine connecting the output to ground and taking the desired band of frequencies from what is usually the earth (at the bottom of the diagram). Well, the "notch" frequencies get dumped to earth, right? So I can pick them up from there. Maybe? Or completely wrong?
An even trickier question that I'd like to know is: what is the output impedance of a Twin T used in this way?
thanks for any help.
cheers
Brett Robinson
Bill Mountain
If you put it into the feedback loop of an opamp it should reverse it's operation.
granny at the G next satdy eh.
See http://www.geofex.com/article_folders/wahpedl/wahped.htm#twintee for the use Bill mentions.  PAIA once offered a wah-ish circuit using this, and I believe that the Coloursound inductorless wah is this way, IIRC.
The Twin T circuit works by causing a phase shift on one leg that can be used to cancel the oppositely-shifted signal on the other leg.  I'd have to do some navel-staring to think about whether the center leg current peaks at this frequency or not. If it does, then to keep the Q high, you'd need to run the center leg current into a virtual ground to keep the Q up.
Bootstrapping the center leg from a low-impedance opamp output is used to raise the normally-low effective Q from about 0.3 or so to higher values. See
http://www.geofex.com/article_folders/eqs/paramet.htm for how you might do this.
tubegeek
#4
Would it work as a bandpass if you swapped 2C for R/2? That's typical filter behavior, dunno if this one is a special case. Putting the R's all in one leg would establish a constant cut at all frequencies, the all-C's leg would do .... something ....
EDIT - I may be talking nonsense....
brett
Thanks all.
I was interested in avoiding an extra opamp (laziness, really).
Haven't heard of a Bridged T. So much fun to read about something new.
Have a great day.
Brett Robinson
A General Approach to Twin-T Design and Its Application to Hybrid Integrated Linear Active Networks
http://www3.alcatel-lucent.com/bstj/vol49-1970/articles/bstj49-6-1105.pdf {16MB PDF}
The General Second-Order Twin-T and Its Application to Frequency-Emphasizing Networks
http://www3.alcatel-lucent.com/bstj/vol51-1972/articles/bstj51-1-301.pdf {5MB PDF}
The papers are dense, but bibliograpies are excellent; as is the history in the beginning of the first paper.
samhay
Quote from: brett on February 16, 2014, 06:43:06 PM
If you want to generate a narrow bandpass, you need to either generate quite a lot of gain at the notch frequency, or subtract a lot of gain either side of it. In either case, I suspect you are going to struggle to do this passively.
Here's something I knocked up earlier: http://www.diystompboxes.com/smfforum/index.php?topic=104233.msg933134#msg933134
PBE6
If I'm not mistaken, the bass boost section of the Thor pedal from www.runoffgroove.com uses a bridged-T filter in an non-inverting opamp feedback loop to emphasize a frequency of around 400 Hz, emulating the bass response of a Marshall 4x12 cabinet. Removing the switch and using a pot instead of the fixed resistor made for a really great sounding variable boost. Something like this would probably work well for you, but it does require the extra opamp.
mac
#10
Colorsound Inductorless Wah in LTSpice,
http://www.diystompboxes.com/smfforum/index.php?topic=99448.0
It needs some tweaks to make it more like a real wah.
mac
bufferz
Quote from: PBE6 on February 19, 2014, 12:42:41 AM
Nice, maybe make both fixed resistors variable?
