Echo Base Debugging
Started by maurice, July 13, 2013, 07:02:22 PM
maurice
continuity seems to be good on lug 2 to gnd for mod depth.  Any other suggestions?
I'm confused now then  ??? if you have continuity between lug 2 and ground when it's turned all the way down then you must get zero volts but you said "Mod Depth is fluctuating between 4.9-6v but does not read zero when tuned down," was this measuring from lug 2?
