Old Space Filter WIP thrown open
Started by StephenGiles, April 05, 2014, 10:08:11 AM
StephenGiles
Quote from: nocentelli on April 10, 2014, 12:28:40 PM
Quote from: StephenGiles on April 06, 2014, 05:20:58 PM
https://www.dropbox.com/s/5ffoimb5uefgux1/Space%20Filter%20ver%203.png
Finally found a second 13700 in my dead veroboard pile, going to try this out tonight.
Excellent, now I have a breadboard again I intend to devote some time to it over Easter.
StephenGiles
How do we make IC1b output respond ONLY to the leading edge of a guitar note, so that any jitter arising from it's decay would be ignored by the envelope generator, yet still be proportional to the strength of the guitar note played?
I think that may be the missing link here.
armdnrdy
I've read in different threads R.G. explaining that this is kind of the hard part!
He did mention a circuit that pulls it off to a better degree than most.....I'll have to see if I can locate that thread.
I think that it was within the last month but....as I'm getting older...sometimes what seems like a month turns out to be a year!  :icon_wink:
StephenGiles
I'm thinking perhaps an "adaptive" leading edge trigger together with a sample & hold might hold some clues?
armdnrdy
Check out MFOS sub commander to see how Ray Wilson implemented that section.
I listened to the sound sample and...it tracks extremely well!
http://www.musicfromouterspace.com/analogsynth_new/GUITARSYNTHAUG2007/GUITARSYNTHAUG2007.html
StephenGiles
Thanks Larry, I'd forgotten about that  - need to study the circuit description.
armdnrdy
#27
Here's something else that might be useful:
http://www.musicfromouterspace.com/analogsynth_new/SOUNDLABMINISYNTH/guitartrigger/guitartrigger.html
I haven't looked into the compatibility with your circuit but....it's something to check out.
Or better yet...this one is powered by 9-15 volts instead of a bipolar supply.
http://www.musicfromouterspace.com/analogsynth_new/HOT_TIPS/PDF/guitargatenov2012.pdf
StephenGiles
Quote from: armdnrdy on April 16, 2014, 03:18:47 AM
I'm just wondering if those gates/triggers go high to a fixed highth (!!) as opposed to an "adaptive" highth proportional to strength of guitar notes played.
Anyway thanks for the links from which I have printed out the articles for breadboarding.
armdnrdy
#29
I have a feeling that "as is" it doesn't provide for dynamics.
Here's another link with a brief description:
http://www.musicfromouterspace.com/analogsynth_new/HOT_TIPS/guitartogate.php
It states that this circuit was designed to be followed by a VCA or VCF.
That is where you might be able to gain back pseudo dynamics.
Edit:
I just thought that you will still have dynamics in the dry guitar signal if you add a mix control or wet and dry level controls.
StephenGiles
Maybe the spare OTA in IC2 could be used as a "comparator peak follower" - so that if a threshold voltage is exceeded, it momentarily peaks to that higher voltage.
StephenGiles
Any mileage in the one shot properties of a cheap old 4047 I wonder?
