Adding gate LED to MXR Noise Gate? Any Simply Way?
Started by nguitar12, May 08, 2014, 10:33:32 AM
nguitar12
Hey guys I am going to build a Noise Gate.  This is the one I am going to work on.
Just Wondering if there is any simply way to add a gate LED so that I can clearly know that when the pedal is taking effect?
Thanks all
Edit:
Unfortunately I don't have exact schmatic for this layout but since say it is based on schematic on tonepad.com so I guess this is:
http://www.tonepad.com/getFile.asp?id=77
If anyone one can help than I will build the tonepad layout instead of that on the top
armdnrdy
You should post a schematic or link for best results in getting an answer to your question.
nguitar12
nguitar12
#3
Edited: Sorry double post. Please ignore this reply.
armdnrdy
You actually might want to find another noise gate to build....
The MXR noise gate has a long history of build problems.
Cut and paste "MXR noise gate" into the forum search engine.
http://www.diystompboxes.com/smfforum/index.php?action=search2
armdnrdy
Fender3D
Expecially when following a wrong schematic ;)
Don't worry about matching 2 transistors doing 2 different things...
Q2 drives the FET, well if you add a resistor it can drive another transistor + LED and give the function requested...
Edit:
damn, Larry beated me for a bunch of seconds  :icon_mad:
nguitar12
Quote from: Fender3D on May 08, 2014, 11:31:29 AM
Edit:
So if this this is the way adding the led?
This layout is verifyed so I will prefer this one.
Thanks so much
Fender3D
nguitar12
Quote from: Fender3D on May 08, 2014, 12:22:49 PM
yep,
better add a 47k/100k at 5088's base
Thanks. What is the different between 47k and 100k being used?
Fender3D
