70's Morley power Wah: footswitch witing help
Started by jonny toetags, May 15, 2014, 09:37:35 AM
jonny toetags
Hi guys,
I have an old Morley Power Wah and I want to add LED's with 3DPT's.
These are the original footswitches:
and what I've done so far:
I tapped into the 25V rail to power the LEDs. If I ground the (-) on teh chassi, they light up fine.
I'm just having issues figuring out the proper way to wire the new switch.
Mustachio
Hey Jonny, I used to have an old morely power boost wah, But since I don't have one in front of me any more I don't know what each wire goes too. Did a short search on the net for a pic with labels but no luck, I'm sure theres one out there though.
Anyway you can still figure this out , One switch you have there should be wired like a regular bypass dpdt switch and the other is for the boost option or what ever option your model has.
Here's a link to how the switches work
http://www.diystompboxes.com/smfforum/index.php?topic=970.0
And Here's a bunch of ways to wire your bypass switch.
//Ops forgot to add the link to the switch wiring//
http://generalguitargadgets.com/tech-pages/51-switching-and-wiring/33-many-bypass-switching-options
You should be able to wire it the same pretty much and use the extra row of lugs to flip the ground on the led's ... I think ... Good luck.
"Hhhhhhhnnnnnnnnnnnnngggggggg"
Dave W
That's where it's at.
