try this link
Started by Gix, May 14, 2014, 09:25:27 AM
gasmask
thats nice link, man. Are there any high wattage transistor amps?
Quote from: gasmask on May 14, 2014, 03:23:06 PM
There are, but don't be seduced by the idea that if you have a schematic for a high power amp, it's easy to build. A power amp is primarily a big honking power supply, big heat sinks, and a sturdy chassis designed for the heat sinks and weight of the power supply. The actual power amp is very nearly an insignificant wart on the rest of it, in terms of both cost and difficulty. If you had a completely built set of power amp boards, building the rest of the power amp to house them in would be almost as difficult as starting from zero.
tca
This type of questions about amps occurs frequently. How many times have you written this sentence?
You should write a article about the "the technology of an guitar amplifier"  ::)
Cheers.
Quote from: tca on May 15, 2014, 02:32:09 AM
+1  Having been around this forum for a while now, and thanks to the insights from R.G. and others, I now think of an amplifier as nothing more than an audio-modulated power supply.
