Building Tip - DC Jacks
Started by italianguy63, May 31, 2014, 07:43:04 AM
haveyouseenhim
Quote from: italianguy63 on May 31, 2014, 10:21:04 AM
Oh, and Mike--
I CAN shoot.  Ready for that duel?
MC
www.youtube.com/watch?v=Mzcgyk62cHU        :icon_mrgreen:
http://www.youtube.com/haveyouseenhim89
I'm sorry sir, we only have the regular ohms.
nocentelli
Quote from: Jdansti on June 02, 2014, 10:27:28 PM
Are you using solid or stranded wire?  I use 24ga stranded and never have problems with wires breaking. I do have problems if I use solid.
I think the issue is with the very thin stranded wire that is common on battery snaps.
italianguy63
Duck--
Yeah, I do exactly that technique-- I tin it, bend it back on itself, and cover it in shrink.
The wires are just thin and crappy.  Stranded.  I have about 4 different kinds of snaps-- all crappy.  What I did here is time consuming, but it does add alot of strength/durability.  It's great if you have the space.  Would not work so well in a 1590A.
nosamiam
Somewhere there's a tutorial for making your own battery snaps by supplying your own heavier gauge wire, tearing apart dead batteries and using the ends, and using a hot glue gun to make it all hold together. I've used this method and it works exceptionally well, even if it looks a little ugly. The only hard part is soldering the wires to the battery snap terminals without melting the plastic that the terminals are embedded in.
