riddle me this...
Started by kurtlives, June 03, 2014, 10:59:49 PM
kurtlives
I am hooking my iPhone to this little preamp then into my tube stereo amp.
http://www.beavishifi.com/projects/JFET_preamplifier/Beavis_HIFI_JFET_Ipod_Preamp_Schematic_v1_1
The output of that little JFET preamp goes to a single 3.5mm stereo jack. This stereo jack goes to a stereo cable/dual RCA cable. The RCA cable goes to my stereo amp. The stereo cable/dual RCA cable works 100%. However, whenever I try to use this setup only one channel works. The audio stops at the 3.5mm stereo jack. I tried two different stereo jacks, both stop the signal.
If I use a single RCA jack for the output of both channels and connect those to my stereo the system works.
What am I missing here...  :( ???
My DIY site:
www.pdfelectronics.com
kgull
What 1/8" jack are you using? Some normalized mono jacks look a lot like a stereo jack (for example).
kurtlives
Quote from: kgull on June 03, 2014, 11:47:21 PM
I am using something that looks very similar to that. Though I tired another different jack and same results.
My DIY site:
kgull
See if any of the 2 pins short together when you either plugin or unplug the cable. If so you've got a normalized mono jack.
kurtlives
Quote from: kgull on June 04, 2014, 12:00:03 AM
Signal pins short together when nothing is plugged in.
Never heard of a normalized mono jack, I will have to read into them...
My DIY site:
