Whilst looking for a polyphonic octaver pedal
Started by FUZZZZzzzz, September 03, 2014, 10:09:56 AM
FUZZZZzzzz
I stumbled upon this badboy
http://www.aliexpress.com/item/Beta-Aivin-OC-200-SUPER-OCTAVE-Guitar-Pedal-polyphonic-octave-function-Drive-mode-add-a-wild/1462898827.html
very affordable 66.5 dollar and no shipping.. have not found any videos yet, though
The updated SUPER OCTAVE equipped with polyphonic octave function, Drive mode add a wild distortion sounds to the octave.
Input Impedance   1K ohm
Output Impedance   1K ohm
Recommended Load Impedance   10 kΩ or greater
Residual Noise   -90dBu (IHF-A, Typ.)
Jack   Input , Output ,AC Adaptor
Power Supply   DC 9V; Dry battery (6F22/9V), AC adaptor(without battery in the package for sending by post air mail)
Controls   Pedal , Mode,OCT/OCT 1, GAIN/OCT 2, Drive/Direct Level
Indicator   Check Indicator (Serves also as battery check indicator)
Current Draw   21mA, (DC 9V)
Dimensions   127*98*53mm
Weight   400g (no battery)
http://www.beta-aivin.com/english/products/Effect/ZOO/index.html
samhay
A 21 mA draw is probably too low for digital, so 'polyphonic' might mean two octaves up rather than 'you can play chords without it turning into a horrible mess of IMD.
nocentelli
I think it is more likely to be a sub-octaver, possibly a near-clone of the BOSS OC-3 since it seems to have many shared functions.
The OC-3 super-octave mode is only "sort-of" polyphonic, not like the EHX POG (where an octave is added to every note in the chord played), but rather that you can play a chord, and it senses the lowest note in that chord and adds an octave below that.
Falken
If you're looking for an Octave pedal on the cheap, may I recommend the Mooer Pure Octave pedal.  It allows 2 octaves up and 2 down with volume for each plus the dry signal.  Tracks extremely well.  It isn't a POG, but neither is the price.
