MY Vero Blackstar PICS
Started by mykaitch, September 09, 2014, 10:40:25 AM
mykaitch
The grille was made from alu tube and chrome tape
Great mod! O/P level goes right up to 11
I made two boards so that each could be tested on its own. This is the low volts brd
This is the valve stuff that hurts if you touch the wrong bit
Valve bd and chassis fitted
All fitted
I only ever use wires on the copm side for power. This is the copper side
(except the valve bit which is all on top)
General views...
mykaitch
If you want to see them they are at www.mikehoughton.co.uk\Blagstar
No idea how this forum works.
myk, not sure wot you rit this time, but this is wot you gotta rite next time:
[img]http://www.mikehoughton.co.uk\Blagstar\valvefitted.jpg[/img]
or just click , then insert your image address within.
don't be shy using the resize facillity, either.
[img height=300]www.blah.notreal.com/blank.jpg[/img]
" I will say no more "
